Evolve LSM-15 Single Switch Wiring Help
Hi all,
I feel like a bit of a dummy here. I’ve replaced many receptacles in my house in the past with dimmer switches and replaced many light fixtures, but for the love of all that is good I can’t figure out this Evolve LSM-15. My current switch is a single switch with 1 black, 1 white and a ground. The LSM 15 has a blue wire. I can’t figure out where to wire this too. I tried just doing the black, white, and green, and the green light comes on the switch, but my light just pulses really dimly. What am I doing wrong here? Where does the blue go?
blue is load, it goes to the light
black is line, white is neutral, green is ground
your existing switch is single pole switch or was it part of a 3-way?
Single pole. There is nothing else on that line it looks like.
See attachment. I labelled the colours due to the shadows from the flash
the white is load, it goes to the light…
what you need is a dimmer with no neutral, or if you want to use that switch, somehow get a neutral wire to that box.
do yourself a favor and put some black electrical tape on that white wire to let you know later (or someone else) that the white wire is hot, not neutral.
the led is powered from the hot wire, that’s why it came on. It leaks a little current over to the load, that’s why the lamp lit a little.
So for this particular outlet the LSM-15 is useless?
outlet? you mean switch, right?
yes, you cannot use that (nice) dimmer switch in that location without adding a neutral. That dimmer switch requires a neutral line. There are switches dimmers that don’t require a neutral (e.g. GE-45606) but they do a poor job on LED’s… incandescant only.
Right. I meant switch. I guess I should have checked the switch before purchasing as it does say a neutral wire is required, but didn’t say anything about being a dimmer switch.
you are right, It is an on/off switch.
you can replace it with the GE dimmer, but you’ll have the issues i mentioned.
So as I was walking out the door today I noticed my light switch without a neutral wire has a light switch on the other side of the wall with a neutral wire. I’m going to see if I can get my electrician friend over to have a look. Appears that I might be able to run this through and get this working after all. In the meantime, I have an automated bathroom light LOL.
If there is a neutral in the other box, and you verified it by actually testing the voltage in every switch position, than you can run a line from that neutral to your neutral connection in the new switch.
Be careful, because you already know that White Wire does not equal Neutral
