Evolve Dimmer Switch LRM-AS and LTM-5
[quote=“Z-Waver, post:20, topic:177081”]I’ve seen the Evolve spec sheets that you linked to, but they aren’t helpful in this case.
Observe the section on association groups in page 2 of the Linear manual. If your Evolve manual has had this section removed, it may be that Evolve has removed multi-group association support from the switch. It sounds like this is the case. If so, you’re stuck with a single GroupID 1.[/quote]
I have managed to source all the manuals for both product lines. It seems that the Evolve version of both the WD500Z-1 (LSM-15) and the WT00Z-1 (LTM-5) do not support more than one group where the Linear versions support 3 and 4 groups respectively, with 5 devices per group.
See links below
LSM-15: ftp://act-solutions.com/Megaworld/Quotes/Zwave/ZRW153%20and%20LSM15/Evolve%20300%20Series%20(LSM-15)/Instructions/LSM-15_2.pdf
WT00Z-1: http://www.linearcorp.com/pdf/manuals/WT00Z1_manual.pdf
LSM-5: ftp://act-solutions.com/Megaworld/Quotes/Zwave/LTM-5/Instruction%20Sheet/Archive/LTM-5%20S300%20R5.1_Inst.pdf
WD500Z-1: http://www.linearcorp.com/pdf/manuals/WD500Z1_manual.pdf
