I’ve been using Evolve LRM-AS dimmers with LED lights without any issue until tonight.
I changed out two GE LED 40W (5W actual load) LED5DG16-C3/TP2P lamps in my ceiling fan. GE shows the lights as dimmable and the Evolve dimmers have a neutral so there should be a problem but they go nuts when trying to dim them.
Just as a check I took out one of the lights and put a standard bulb and the remaining LED dimmed normally. That an action I’d expect to see with a dimmer with no neutral. Tomorrow I’ll double check that the Neutral didn’t get disconnected.
I’ve run the Evolve dimmers with a single 15W LED and they worked fine.
These dimmers are at least 4 years old just incase that has something to do with the problem. I guess it’s possible newer Evolve dimmer wouldn’t have the same issue or maybe the GE LEDs are just junk.
