Hello,
I bought a Everspring ST814 to use as a trigger to control a ventilation fan. Including the sensor in my Vera Edge (latest FW) is no problem. The device shows up as a parent with two children. Also the device reports the temp and humidity just fine.
My idea is to use an association from the Everspring to the fibaro switch that controls the fan. For that i go to the humidity sensor device and in device options i add group 2 to the association group. So far so good. I then configure the device that needs to be controlled by the sensor. After i choose the right device the Vera restarts something on the background and updates the configuration.
But when i go back to the devices list it is almost completely empty >:( My action deleted all my other devices including cameras and apps. Only the Everspring and switch i tried to associate it with are still there.
Any ideas how to tackle this…???
