Everspring Door Sensor Doorbell Short Press Trigger fail
I have searched a lot of the forum and have not been able to find an answer to my specific problem, so I am putting it out there. thanks in advance for any helpful tips. I have an everspring door sensor wired to my doorbell separate and independent to any house wiring. when the doorbell is given a short press the light on the sensor turns on red but won’t trigger in vera. when I give it a slightly longer press it triggers in vera. I don’t really want to put a sign up that says please push and hold doorbell. any thoughts on how to have the short presses trigger in vera?
thanks
Dawson
Got the same issue with a fibaro sensor , used for the same purpose.
My work arround:
create a virtual switch.
create a scene with a trigger from the sensor
the scene toggles the virtual switch on and after for example 5 seconds off again.
notification on the virtual switch.
good luck,
Cor
This might be of interest too…
http://forum.micasaverde.com/index.php/topic,13753.msg103336.html#msg103336
Here is how I did my door bell and it triggers with even with a very quick push of the button. The existing door bell was broken already so i gutted the insides and mounted the everspring door sensor and a relay like this inside, i took the relay out of the case to make room inside the doorbell so i could put the cover back on and it would look like a normal door bell on the outside. the nice thing about the relay is that it works from 10-30 volts ac and my door bell voltage it 16 volts. I wired the N.C. terminals of the relay right to the external terminals on the everspring door sensor, that way its not always showing as a tripped sensor on the vera UI. then powered the relay from the existing power that powered the door bell when the button is pushed. I did have to remove the light bulb from the door bell button though as it was causing just enough current to pass through it to create issues intermittently.
@SteveZ - is that setup using the RIBU1C that you posted a link to in another forum? [url=http://www.amazon.com/Enclosed-Relay-10Amp-10-30Vac-120Vac/dp/B009PAPJRA/ref=sr_1_2?ie=UTF8&qid=1361926901&sr=8-2&keywords=rib+relay]http://www.amazon.com/Enclosed-Relay-10Amp-10-30Vac-120Vac/dp/B009PAPJRA/ref=sr_1_2?ie=UTF8&qid=1361926901&sr=8-2&keywords=rib+relay[/url]
Can you explain how you wired it and the everspring sensor up? I think I have it worked it out on paper, but I just want to be sure.
Here’s how I think it goes…
10-30VDC/VAC (White/Blue) > Hot on transformer (16/24v)
Common (White/Yellow) > Common on transformer
Normally Closed (Blue) > NC terminal on Everspring
Common (Yellow) > Common on Everspring
[quote=“qwen3579, post:5, topic:181091”]@SteveZ - is that setup using the RIBU1C that you posted a link to in another forum? [url=http://www.amazon.com/Enclosed-Relay-10Amp-10-30Vac-120Vac/dp/B009PAPJRA/ref=sr_1_2?ie=UTF8&qid=1361926901&sr=8-2&keywords=rib+relay]http://www.amazon.com/Enclosed-Relay-10Amp-10-30Vac-120Vac/dp/B009PAPJRA/ref=sr_1_2?ie=UTF8&qid=1361926901&sr=8-2&keywords=rib+relay[/url]
Common (Yellow) > Common on Everspring[/quote]
Yeah that all looks good, as far as the White/blue coil wire goes have that connected to the wire that comes back from other side of the doorbell button so it only energizes when the button is pressed.
[quote=“SteveZ, post:6, topic:181091”][quote=“qwen3579, post:5, topic:181091”]@SteveZ - is that setup using the RIBU1C that you posted a link to in another forum? [url=http://www.amazon.com/Enclosed-Relay-10Amp-10-30Vac-120Vac/dp/B009PAPJRA/ref=sr_1_2?ie=UTF8&qid=1361926901&sr=8-2&keywords=rib+relay]http://www.amazon.com/Enclosed-Relay-10Amp-10-30Vac-120Vac/dp/B009PAPJRA/ref=sr_1_2?ie=UTF8&qid=1361926901&sr=8-2&keywords=rib+relay[/url]
Yeah that all looks good, as far as the White/blue coil wire goes have that connected to the wire that comes back from other side of the doorbell button so it only energizes when the button is pressed.[/quote]
Thanks man. Got it all wired up yesterday and it works perfectly.
