Everspring AN180, Error failed at getting the version
Vera2 UI 1.5.622
Brand new Everspring AN180, very small, like Fibaro FGWPF-102, much cheaper without energy control.
Several times include, exclude, factory reset of the switch → every time the same ‘‘Error failed at getting the version’’.
The switch is controlled from the Vera 100%, but always the red error on the overview and on the board of the module.
What can I do to erase the error? Or to force Vera to not control the version …?
Thanks,
I found a ‘solution’ :-[ to switch off the errormessage, -->in the settings I disable the function Automatically Configure: No …
Bye,
balez1
