I can only suggest that this is a Vera issue, rather than an [tt]EventWatcher[/tt] one. Perhaps a support ticket is in order?
I have the ExtraVariables setup and working just fine for my home thermostat (thanks again for your help there), but I tried setting up watt and KWh reporting for the aeon labs smart switches(the values are in the UI) by doing the following :
29.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature
29.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint
29.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeStatus
29.urn:micasaverde-com:serviceId:HVAC_OperatingState1.ModeState
22.urn:upnp-org:serviceId:BinaryLight1.Watts
22.urn:upnp-org:serviceId:BinaryLight1.KWH
the device_type is this :
urn:schemas-upnp-org:device:BinaryLight:1
and device22 is already in the list of devices and reports the status correctly :
61 2015-03-27, 11:21:48.246 X 22 Humidifier Status 0
just want to capture the Watts and KWh used, too.
thanks again for all your help.
I answered my own question !
22.urn:micasaverde-com:serviceId:EnergyMetering1.Watts
22.urn:micasaverde-com:serviceId:EnergyMetering1.KWH
and it works, too!
for future reference, for those interested in being self-sufficient, the way to get to the data is to ssh to your vera box, then run the following :
grep 'device: 22' /tmp/log/cmh/LuaUPnP.log | grep Watt | tail -1
you just need to use the correct device ID, and here’s the answer you get :
06 03/27/15 11:31:44.685 Device_Variable::m_szValue_set device: 22 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: Watts was: 114 now: 64 #hooks: 1 upnp: 0 skip: 0 v:0xb23418/NONE duplicate:0 <0x2bc8a680>
and to take it one step further, if you want to know what variables a device logs to, run the following :
grep 'device: 22' /tmp/log/cmh/LuaUPnP.log | awk '{print $8}' | sort -u
awk ‘{print $8}’ prints the 8th value in the line
sort -u sorts and returns unique values
so device 22, the aeon smart switch reported :
urn:micasaverde-com:serviceId:HaDevice1
urn:micasaverde-com:serviceId:ZWaveDevice1
urn:upnp-org:serviceId:SwitchPower1
now, obviously the bigger your log file, the more accurate the list will be, but you get the idea.
hopefully, this helps one person one day. ![]()
