Events created outside Vera
I am creating an outside UI for a touchscreen computer, the basic screen has already been posted…a multi channel dimmer and door sensor status display. I am adding visual logic generator so that a typical user can set up fairly complex events with no code to write. Thanks to everyones help I am able read and write variables to Vera no problem. The next step is to use Vera to handle events that involve notifications and camera functions. I will be handling lighting commands myself with Vera as the controller.
That being said does anyone have any suggestions on notifications (I will start there) and how changing a variable inside Vera could be used as a trigger.
As usual I am trying to limit LUAA coding! Ha
Regards
Tim Alls
AllSeas Yachts
http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_variable_watch might be useful.
