This is probably a stupid question, but I just got to have i right. I live in Sweden and have a Vera and some other devices bought in Europe with the EU frequency.
I really want a door lock to connect to my Vera, but I have only found Schlage and Kwikset locks for the US frequency.
Should I just forget about it and wait for the manufacturers to build locks for EU, or is possible in some way to get a US device work in an EU environment?
You can get an US Z-Wave dongle and connect it to Vera. But you loose access to your EU frequency devices. Another solution is to use 2 units. But AFAIK, it’s illegal to use another frequency than the country signed for (at least in US).
AFAIK, you cannot simultaneously use EU and US frequencies on Vera V1 or V2 (V1 supports one dongle only, and V2 has no additional slot to connect an additional Z-Wave module) - but you could try setting up the first Vera for EU frequencies and the second one for US frequencies and bridging both Veras. Please note that it may be illegal in your country to use the wrong frequency.
Just a quick question, is it possible to add a USB US Zwave dongle to a Vera3 to use US Zwave appliances?
There are more US appliances then EU, so an addon USB stick would come in very handy.
I think actually you can use your own zwave stick; it’s recommended for austraiia for instance, I read somewhere. You can set the port for the zwave output in the setup somewhere.
Having dual z-wave controllers seems very useful for european users. This way, for example, US based battery operated sensors, locks, etc. can be used in the EU.
Leaving the legal issue aside, from a purely technical perspective, can Vera use two z-wave dongles (one internal and one external) at the same time?
It should work. The bridging just allows both Vera units to communicate over the network. They do not communicate via zwave. Say you have Vera 1 and Vera 2. Vera 1 can not control a zwave device directly that is included in Vera 2, only the Vera 2 can communicate to the device via zwave. Vera 1 just tells Vera 2 I want to turn this light on, Vera 2 will than turn on the light and tell Vera 1 the status.
Yes, as long as the US Version of Vera controls the US devices. Just to “warn” you, it is illegal to use a frequency that is not approved by your local / country laws. But I am sure you are aware of that.
These guys sell some Euro locks. They look suspiciously like American locks; maybe they just stuck a Euro Zwave chip in them. In any case, this may be what you’re looking for.
[quote=“sagi4422, post:19, topic:166824”]Long time without any new post…
Wondering if it is possible to bridge EU Vera with USB stick controller (such as the DSA02203-ZWUS from AEON labs) ?[/quote]
Yes. Vera bridging is done via TCP/IP and has not connection to the Z-Wave frequency.
Note that bridged Veras must be using the same ui version firmware.
