etherrain and ui5
i’m waiting to get my etherrain in and has a couple of questions. pretty much i’m uisng over the vera for manual control if away and need to water cause it is a day that my hunter is not programmed to run.
i assume i can just do a simple on and off from the vera?
also when setting up all i need to install is the plugin from the app store right? no need for those other 2 xml files a saw from older ui’s?
finally since i’m still running the hunter when i wire the 2 together can i just take new wires from the hunter terminals to the etherrain or should i take the field wires and use wire nuts to split each wire into 2 sets to take to the hunter terminal and the other set to the etherrain terminals. didn’t know if i just screwed down into the hunter terminals with the new wires out to the etherrain if it would mess either up.
thanks a lot. sorry if these are stupid questions. i read through the 8 pages of the etherrain thread but it’s alot of old info.
thanks,
jim
[quote=“jimim, post:1, topic:176429”]i’m waiting to get my etherrain in and has a couple of questions. pretty much i’m uisng over the vera for manual control if away and need to water cause it is a day that my hunter is not programmed to run.
thanks,
jim[/quote]
got everything answered!
just waiting for my ether rain now. i’ll post back when i get it up and going so maybe my experience will help someone else out.
one thing i learned so far is that the ac line adaptors are very cool. i never used one before. i picked up a netgear nano 200 today and had a wired drop in the garage in 30 secs. seriously 30 secs. it works with my laptop so i would assume with etherrain i should be good too.
jimi
