Etherrain 7p will work with Vera Plugin?
I have the Etherrain 8 and it works well with Vera plug in UI5. This is with my vacation house in Santa Fe so water management is important. Although I was not that familiar with the irrigation system at the house it turns out to have a master control value which means that it would be best to use the Etherrain 7p, however I don’t know if the plug in will work with the 7p?
Has anyone used the vera plug in with the 7p?
Hello yoabear,
Yes ER7P works with the plugin. When using ER7P the pump control/master valve signal is automatically managed by EtherRain. It will turn on a few seconds before the cycle starts and will turn off when the cycle has finished. Any value that you enter in zone 8 in the plugin field is ignored.
Cheers
ERdevman
Thanks - I confirmed that it does work as designed.
