I was looking for something unrelated in my log, and have seen these errors relating to PLEG. I think my PLEG is running fine, but going through the log i can see these regularly. As i said, not causing any issues as far as i am aware, but they might point to a bug so i thought i post it here. I cannot see anything related to PLEG around these errors in the log but i dont really know a lot about interpreting the log…
02 11/10/13 9:09:15.824 ZW_Send_Data node 61 NO ROUTE (nil) <0x2c24d680>
01 11/10/13 9:09:17.055 luvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn’t exist <0x3088e680>
01 11/10/13 9:09:17.069 luvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn’t exist <0x3088e680>
01 11/10/13 9:09:17.108 luvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn’t exist <0x3088e680>
01 11/10/13 9:09:17.121 luvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn’t exist <0x3088e680>
Ignore the file extension … do you see a file with the name S_ProgramLogicEG
When you go to Apps → Develop Apps → Luup Files ?
If so … I would not worry about this message.
Yes i have that. I’ll ignore the errors.
mikee123 - I noticed the same thing in my logs. But I see similar errors for some non-RTS plugins, too. Hasn’t affected the performance of my Vera.
I wanted to chime in and say all of the sudden I am getting this message and my pleg is not working any more.
FWIW, I get those errors constantly, but it hasn’t affected my PLEGs.
It affected my pleg as it would not work at all. I downloaded the files and re-uploaded them and all is working again.
Running into the same problem. Is there somewhere the files can be downloaded?
You can login to Vera and delete all of the PLEG/PLTS files.
Then restart Vera … It should detect this and re-download them.
This problem seems to be a Vera Problem.
There is anything I can do to fix it. At least that I know of.
Understood Richard. I know it’s not a PLEG issue.
Thanks so much for the advice. I’ll try that. Was hoping there was a direct download link like code.mios.com for PLEG and avoid the reinstallation route since I have 2 PLEG entries with about 30 activities each
The approach I gave does NOT require you to delete your plugins.
You will not loose any information.
If you uninstall you WILL loose your data.
I hardly ever recommend people to UNINSTALL any plugin.
[quote=“RichardTSchaefer”]The approach I gave does NOT require you to delete your plugins.
I hardly ever recommend people to UNINSTALL any plugin.[/quote]
Except that ergy plug in!
ah, appreciate the clarification. That’s a relief.
Thanks again richard!
Just reporting back. Deleting the files didn’t work sadly. Vera did try to re-download, but it’s showing some odd errors in the log on boot and the files are still missing:
03 12/18/13 12:28:05.545 UserData::LoadUserData BuildVersion: *1.5.622* SvnVersion: *7546* Model: 33 MiCasaVerde VeraLite flush: 0 changed: 0 resync: 5119 syncdevice:0 <0x2b23a000>
02 12/18/13 12:28:05.575 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download plugin 5e[0m <0x2b23a000>
02 12/18/13 12:28:05.575 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set plugine[0m <0x2b23a000>
01 12/18/13 12:28:05.739 e[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xmle[0m <0x2b23a000>
02 12/18/13 12:28:05.739 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xmle[0m <0x2b23a000>
01 12/18/13 12:28:05.740 e[31;1mJobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 97/D_ProgramLogicC.xml so device 97 is offlinee[0m <0x2b23a000>
01 12/18/13 12:28:05.740 e[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicEG.xmle[0m <0x2b23a000>
02 12/18/13 12:28:05.741 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicEG.xmle[0m <0x2b23a000>
01 12/18/13 12:28:05.741 e[31;1mJobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 98/D_ProgramLogicEG.xml so device 98 is offlinee[0m <0x2b23a000>
01 12/18/13 12:28:05.741 e[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicEG.xmle[0m <0x2b23a000>
02 12/18/13 12:28:05.742 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicEG.xmle[0m <0x2b23a000>
01 12/18/13 12:28:05.742 e[31;1mJobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 99/D_ProgramLogicEG.xml so device 99 is offlinee[0m <0x2b23a000>
01 12/18/13 12:28:06.586 e[31;1mDevice_LuaUPnP::CreateServices Aborting device 97 because the topmost device has no interfacee[0m <0x2b23a000>
01 12/18/13 12:28:06.586 e[31;1mJobHandler_LuaUPnP::CreateAllServices failed to create 97e[0m <0x2b23a000>
01 12/18/13 12:28:06.587 e[31;1mDevice_LuaUPnP::CreateServices Aborting device 98 because the topmost device has no interfacee[0m <0x2b23a000>
01 12/18/13 12:28:06.587 e[31;1mJobHandler_LuaUPnP::CreateAllServices failed to create 98e[0m <0x2b23a000>
01 12/18/13 12:28:06.587 e[31;1mDevice_LuaUPnP::CreateServices Aborting device 99 because the topmost device has no interfacee[0m <0x2b23a000>
01 12/18/13 12:28:06.587 e[31;1mJobHandler_LuaUPnP::CreateAllServices failed to create 99e[0m <0x2b23a000>
01 12/18/13 12:28:06.971 e[31;1mUPnPAction_Send::ParseState can't find namee[0m <0x2b23a000>
02 12/18/13 12:28:07.042 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.046 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:DSCAlarmPartition1e[0m <0x2b23a000>
02 12/18/13 12:28:07.050 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.089 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.095 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.111 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.114 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.147 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.176 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.179 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.192 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.196 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.199 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.200 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:rts-services-com:serviceId:ProgramLogicCe[0m <0x2b23a000>
02 12/18/13 12:28:07.216 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:rts-services-com:serviceId:ProgramLogicEGe[0m <0x2b23a000>
02 12/18/13 12:28:07.217 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:rts-services-com:serviceId:ProgramLogicCe[0m <0x2b23a000>
02 12/18/13 12:28:07.218 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:rts-services-com:serviceId:ProgramLogicEGe[0m <0x2b23a000>
02 12/18/13 12:28:07.218 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:rts-services-com:serviceId:ProgramLogicCe[0m <0x2b23a000>
02 12/18/13 12:28:07.234 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
02 12/18/13 12:28:07.238 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1e[0m <0x2b23a000>
01 12/18/13 12:28:07.254 e[31;1mDevice_LuaUPnP::CreateImplementations Aborting 97 because it failed to loade[0m <0x2b23a000>
01 12/18/13 12:28:07.255 e[31;1mJobHandler_LuaUPnP::CreateAllImplementations failed to create 97e[0m <0x2b23a000>
01 12/18/13 12:28:07.255 e[31;1mDevice_LuaUPnP::CreateImplementations Aborting 98 because it failed to loade[0m <0x2b23a000>
01 12/18/13 12:28:07.255 e[31;1mJobHandler_LuaUPnP::CreateAllImplementations failed to create 98e[0m <0x2b23a000>
01 12/18/13 12:28:07.255 e[31;1mDevice_LuaUPnP::CreateImplementations Aborting 99 because it failed to loade[0m <0x2b23a000>
01 12/18/13 12:28:07.255 e[31;1mJobHandler_LuaUPnP::CreateAllImplementations failed to create 99e[0m <0x2b23a000>
[code]04 12/18/13 12:28:14.386 <0x2bd6d680>
01 12/18/13 12:28:14.542 e[31;1mJobHandler_LuaUPnP::DownloadPlugin 5 failed to convert error -4: ERROR: no version relased for this plugine[0m <0x2bb6d680>
01 12/18/13 12:28:14.542 e[31;1mJobHandler_LuaUPnP::DownloadFiles new plugin 5 returned 0e[0m <0x2bb6d680>
01 12/18/13 12:28:14.751 e[31;1mJobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1408e[0m <0x2bb6d680>
01 12/18/13 12:28:14.821 e[31;1mJobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 3116e[0m <0x2bb6d680>
02 12/18/13 12:28:16.100 e[33;1mZWaveJobHandler::SetDeviceStatus XXX2 0/0/0/0e[0m LEAK this:114688 start:114688 to 0x1275000 <0x2b96d680>
03 12/18/13 12:28:16.244 JobHandler_LuaUPnP::Reload: Downloaded Files Critical 0 m_bCriticalOnly 0 dirty data 0 LEAK this:81920 start:196608 to 0x1289000 <0x2bb6d680>
06 12/18/13 12:28:16.350 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mNetStatusIDe[0m was: 5 now: 2 #hooks: 0 upnp: 0 v:0xff9ad0/NONE duplicate:0 <0x2bb6d680>
06 12/18/13 12:28:16.351 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mNetStatusTexte[0m was: Configuring ZWave devices now: Resetting ZWave Network #hooks: 0 upnp: 0 v:0xffb8f8/NONE duplicate:0 <0x2bb6d680>
01 12/18/13 12:28:16.559 e[31;1mMongoose XXX-mg_stop1 0xe5e0a8 1 2e[0m <0x2b23a000>
01 12/18/13 12:28:18.560 e[31;1mMongoose XXX-mg_stop2 0xe5e0a8 2 2e[0m <0x2b23a000>
01 12/18/13 12:28:18.560 e[31;1mMongoose XXX-mg_stop3 0xe5e0a8 2 2e[0m <0x2b23a000>
01 12/18/13 12:28:18.560 e[31;1mMongoose XXX-mg_stop4 0xe5e0a8 14224416 2e[0m <0x2b23a000>
e[7;36m2013-12-18 12:28:18 - LuaUPnP Terminated with Exit Code: 250e[1;00m
e[7;36m2013-12-18 12:28:18 - LuaUPnP crashe[1;00m
[/code]
01 12/18/13 12:33:51.470 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:51.473 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:51.476 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:51.479 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:59.955 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:59.958 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:59.961 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn't existe[0m <0x2e833680>
01 12/18/13 12:33:59.963 e[31;1mluvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn't existe[0m <0x2e833680>
Oddly enough, things are at least working, so maybe i’ll just leave it alone for now.
some one that has the problem should open A ticket with MCV
Good suggestion. Done. I’ll report back if any fixes are found.
I’m experiencing this issue now, too. When I opened UI5 on my Vera 3 this morning I had several warnings that my startup lua had failed for all of my PLEGs. Checked the log and I have a ton of the “doesn’t exist” errors. Did you hear anything silencery?
MCV support responded to my ticket asking about the “doesn’t exist” problem with this:
[tt]
I’ve made some changes to your unit but I’m not 100% percent that it will work. (Those are 3rd party plugins, they aren’t created by us)
The issue was that those files are encrypted and they weren’t recognized by Vera.
Instead of xml.lzo they have xml.lzoenc as an extension.
[/tt]
Is the encrypting something that the plugin authors do? I had this issue with several plugins, all downloaded from the MCV app “store”.
I think this is much to do about nothing. I will turn off encryption for this file on the next release.
