I’m quite new to vera, playing around, and looking at the log i see a lot of yellow en red lines, not suire how to solve it, i also installed some plugins to try things (manual intall by oploading files) but i can’t see where/how to delete those files?
here a part of my log:
02 03/10/15 18:42:35.390 JobHandler_LuaUPnP::FetchMissingFiles need to download plugin 5 <0x2b4fb000>
02 03/10/15 18:42:35.391 JobHandler_LuaUPnP::m_sMissingFile_set plugin <0x2b4fb000>
01 03/10/15 18:42:35.450 Device_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//undefined <0x2b4fb000>
02 03/10/15 18:42:35.450 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//undefined <0x2b4fb000>
01 03/10/15 18:42:35.450 JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 4/undefined so device 4 is offline <0x2b4fb000>
01 03/10/15 18:42:36.667 Device_LuaUPnP::CreateServices Aborting device 4 because the topmost device has no interface <0x2b4fb000>
01 03/10/15 18:42:36.667 JobHandler_LuaUPnP::CreateAllServices failed to create 4 <0x2b4fb000>
01 03/10/15 18:42:39.624 Device_LuaUPnP::CreateService 10 service type/url don’t match for urn:upnp-org:serviceId:AVTransport <0x2b4fb000>
01 03/10/15 18:42:39.625 Device_LuaUPnP::CreateServices removing incomplete service from 10 <0x2b4fb000>
01 03/10/15 18:42:39.625 Device_LuaUPnP::CreateService 10 service type/url don’t match for urn:upnp-org:serviceId:RenderingControl <0x2b4fb000>
01 03/10/15 18:42:39.685 Device_LuaUPnP::CreateServices removing incomplete service from 10 <0x2b4fb000>
02 03/10/15 18:42:39.695 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//AlarmClock1.xml <0x2b4fb000>
01 03/10/15 18:42:39.766 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//AlarmClock1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.766 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.766 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//MusicServices1.xml <0x2b4fb000>
01 03/10/15 18:42:39.767 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//MusicServices1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.767 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.767 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//AudioIn1.xml <0x2b4fb000>
01 03/10/15 18:42:39.768 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//AudioIn1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.768 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.768 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//DeviceProperties1.xml <0x2b4fb000>
01 03/10/15 18:42:39.769 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//DeviceProperties1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.769 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.769 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//SystemProperties1.xml <0x2b4fb000>
01 03/10/15 18:42:39.770 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//SystemProperties1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.770 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.771 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//ZoneGroupTopology1.xml <0x2b4fb000>
01 03/10/15 18:42:39.771 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//ZoneGroupTopology1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.771 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.772 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//GroupManagement1.xml <0x2b4fb000>
01 03/10/15 18:42:39.772 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//GroupManagement1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.772 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
02 03/10/15 18:42:39.773 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//QPlay1.xml <0x2b4fb000>
01 03/10/15 18:42:39.773 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//QPlay1.xml for 12/Sonos Kitchen <0x2b4fb000>
01 03/10/15 18:42:39.773 Device_LuaUPnP::CreateServices removing incomplete service from 12 <0x2b4fb000>
01 03/10/15 18:42:39.840 Device_LuaUPnP::CreateService 17 service type/url don’t match for urn:upnp-org:serviceId:RenderingControl <0x2b4fb000>
01 03/10/15 18:42:39.840 Device_LuaUPnP::CreateServices removing incomplete service from 17 <0x2b4fb000>
02 03/10/15 18:42:39.841 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//ConnectionManager1.xml <0x2b4fb000>
01 03/10/15 18:42:39.841 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//ConnectionManager1.xml for 17/Living Room - Sonos CONNECT Media Renderer <0x2b4fb000>
01 03/10/15 18:42:39.842 Device_LuaUPnP::CreateServices removing incomplete service from 17 <0x2b4fb000>
01 03/10/15 18:42:39.842 Device_LuaUPnP::CreateService 17 service type/url don’t match for urn:upnp-org:serviceId:AVTransport <0x2b4fb000>
02 03/10/15 18:42:39.843 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//Queue1.xml <0x2b4fb000>
01 03/10/15 18:42:39.843 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//Queue1.xml for 17/Living Room - Sonos CONNECT Media Renderer <0x2b4fb000>
01 03/10/15 18:42:39.843 Device_LuaUPnP::CreateServices removing incomplete service from 17 <0x2b4fb000>
01 03/10/15 18:42:39.843 Device_LuaUPnP::CreateService 17 service type/url don’t match for urn:upnp-org:serviceId:GroupRenderingControl <0x2b4fb000>
01 03/10/15 18:42:39.844 Device_LuaUPnP::CreateServices removing incomplete service from 17 <0x2b4fb000>
02 03/10/15 18:42:39.844 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//ContentDirectory1.xml <0x2b4fb000>
01 03/10/15 18:42:39.845 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//ContentDirectory1.xml for 18/192.168.1.61 - Sonos CONNECT Media Server <0x2b4fb000>
01 03/10/15 18:42:39.845 Device_LuaUPnP::CreateServices removing incomplete service from 18 <0x2b4fb000>
02 03/10/15 18:42:39.926 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//ConnectionManager1.xml <0x2b4fb000>
01 03/10/15 18:42:39.927 Device_LuaUPnP::CreateService can’t load /etc/cmh-lu//ConnectionManager1.xml for 18/192.168.1.61 - Sonos CONNECT Media Server <0x2b4fb000>
01 03/10/15 18:42:39.927 Device_LuaUPnP::CreateServices removing incomplete service from 18 <0x2b4fb000>
02 03/10/15 18:42:40.308 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:Camera1 <0x2b4fb000>
02 03/10/15 18:42:40.378 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x2b4fb000>
02 03/10/15 18:42:40.379 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:TemperatureSensor1 <0x2b4fb000>
02 03/10/15 18:42:40.379 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:GenericSensor1 <0x2b4fb000>
02 03/10/15 18:42:40.382 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x2b4fb000>
02 03/10/15 18:42:40.382 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:GenericSensor1 <0x2b4fb000>
02 03/10/15 18:42:40.461 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:DeviceProperties <0x2b4fb000>
02 03/10/15 18:42:40.462 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:ContentDirectory <0x2b4fb000>
02 03/10/15 18:42:40.462 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:ZoneGroupTopology <0x2b4fb000>
02 03/10/15 18:42:40.531 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:ConnectionManager <0x2b4fb000>
02 03/10/15 18:42:40.606 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:DeviceProperties <0x2b4fb000>
02 03/10/15 18:42:40.606 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:ContentDirectory <0x2b4fb000>
02 03/10/15 18:42:40.606 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceId:ZoneGroupTopology <0x2b4fb000>
01 03/10/15 18:42:40.607 Device_LuaUPnP::CreateImplementations Aborting 4 because it failed to load <0x2b4fb000>
01 03/10/15 18:42:40.607 JobHandler_LuaUPnP::CreateAllImplementations failed to create 4 <0x2b4fb000>
