I just upgraded to the lastest firmware 1.7.947, which i had my troubles with… but after a struggle or two I finally got the unit back up and running. everything is working except it doesnt see my dimmable lights or my humidity sensor. and it throws out these errors.
System error : Device: 29. Fail to load implementation file D_HumiditySensor1.xml
System error : Device: 66. Fail to load implementation file D_DimmableLight1.xml
System error : Device: 67. Fail to load implementation file D_DimmableLight1.xml
System error : Device: 68. Fail to load implementation file D_DimmableLight1.xml
System error : Device: 69. Fail to load implementation file D_DimmableLight1.xml
System error : Device: 70. Fail to load implementation file D_DimmableLight1.xml
System error : Device: 71. Fail to load implementation file D_DimmableLight1.xml
ZWave : Configuring Z-Wave devices in your system.
ERROR : Error in lua for scenes and events
I have tried to restore to an old back up but the same errors are present… and if I look at the files it would seem that the D_DimmableLight1.xml and D_HumiditySensor1.xml File are not present in the list… any ideas? Ive tried to exclude and reinclude the lights. but still nothing. The vera lights when in battery mode show the device being excluded and reincluded but when I hook it back up to the network, nothing… any ideas would be greatly appreciated!
Did you only restore the backup file? Did you restore the z-wave network? There are 2 backups really so that could be a problem. If nothing has changed just prior to the upgrade and post the upgrade you could always try to restore the z-wave network backup. Maybe this will help but always proceed with caution or call support too.
I restored the z-wave network and the backup file… I even went back to a back-up for a week ago and the files are still missing… Should I factory reset then restore the back up? will that set the firmware back to the lastest or will I need to do the firmware upgrade again?
It seems that some files got corrupted during the firmware upgrade. This could happen if the unit is interrupted in a very specific upgrade phase, where it’s backing up these system files on a backup partition, with the purpose of restoring them, after the clean firmware image is written.
Our Customer Care can easily sort this out if contact them (see my signature)
Did a full backup including z-wave (this takes about 10 minutes)
Restored to factory settings. Lost UI interface but waited until the unit was back up
Plugged the Vera into my router and restarted Vera
Logged into UI, updated firmware, reboot.
Logged into UI, set Wi-Fi, when told to unplug WAN, unplugged Vera to move back to its final place
After Vera restarted, restored from backup including z-wave (this takes about 10 minutes).
During the restore, Vera downloaded and restored the Plug-ins. Warning - Looks like I lost my Data Mine 2 data or at least it was not restored, including which variables I was watching and my saved graphs.
