"Error Restoring Comments" message
Richard, For some reason I seem to be getting the following message from one of my PLEG’s every time I select; Inputs, conditions or Actions. After selecting OK I can then see the expected; Inputs, Conditions and Actions but any previously saved comments against each field is no longer there that I previously inputted. Any suggestions as to how one fixes this? Mike
I’m getting the same. I’t appeared to happen immediatly after adding a new comment to a new condition it was quite a long comment (not sure if that matters). Anyway after reloading Luup it kept popping up with the error message.
Mike, did the same thing happen to you (i.e straight after adding a new comment)?
I’ve managed to get rid of the annoying error message by opening up the last comment I made (it was obviously blank) and typing something new. After Reloading Luup the error message did not appear. The only down side is that all my other comments have gone. :frowning:
