Hi. I started getting ‘Error: No Interface’ error code when I test my Luup code in the test window. Even a single line of trying to assign a variable a value.
All was going well yesterday when it started happening. It as if some background task is no longer running.
Anyone seen this issue before? I was running on version 949, then upgraded to 954, but it also happens there.
Is there a was to rebuilt Vera to ‘factory’ defaults without losing my z-wave stuff?
Thanks,
Brian
