Error executing function pleginit()
Have not used PLEG in awhile but went to revisit the PLEG device that controls my pool pump under freeze conditions. Clicked on the Edit and got the error message “Error executing function pleginit()” followed by the message "Error executing function device_notifications().
Since the device logic was not working anyway, deleted the device and created a new one - same error.
Deleted PLEG and re-installed - same error.
What is a logical next step?
Using UI7 on a veralite.
Did you install the PLC plugin ?
What Version for PLC ? for PLEG ?
Power Cycle your Vera and reload your browser.
Thanks Richard - forgot about the relationship with PLC. Wound up un-installing and re-installing PLC. I now have both working (latest versions). Not sure what went wrong to begin with but all is good for now.
