I followed this from Sorin and I don’t see any incorrect code
[quote=“Sorin”]Hi guys,
Just to ping in. If you are referring to the status bar error "Error in lua for scenes and event ". then you can look in user_data with the following command:
[font=arial][size=13px]VERALOCALIP/port_3480/data_request?id=user_data&output_format=xml[/size][/font]
[font=arial][size=13px]and search for: lua= [/size][/font]
[font=arial][size=13px]And if you see luup code that is NOT encoded and is shown in clear, then, that scene is the issue. Due to latest changes, LUA code in user_data data will show encoded in and it will show something like this : [/size][/font]
lua="aWYgKGx1dXAuaXNfbmlnaHQoKSkgdGhlbgogICAgIHJldHVybiB0cnVlCiAgZWxzZQogICAgIHJldHVybiBmYWxzZQogIGVuZA==" encoded_lua="1"
So in user_data.xml …
Correct:
NOT Correct
if (luup.is_night()) then
return true
else
return false
However, on Vera graphical user interface, the luup code will still be shown in clear. The mentioned change is for user_data only.
Also, XA44Owq26HxCq88 - you mention that you Deactivate scene from the mobile app. - We have discovered a recent bug in the iOS mobile app, which is conjunction with scenes that contain luup code, causes the scene to break, by removing the encoding from user_data,. We have reported this and it will be fixed with the upcoming update of the mobile app. So for the moment, avoid Deactivating the lua containing scenes, from the mobile app.
Solution:
Copy the code, somewhere safe → delete it from the scene → Save scene without code → edit the scene again → add the luup code again → double check user data, to make sure it shows encoded.
Hope this info is of help, and makes sense
but feel free to ask, is something is unclear.[/quote]
