Error after automatic update
I had a automatic update of my PLEG’s, and since this update whenever I open one of them i have the following error:
Version mismatch! PLEG Version: 7.33 PLC Version: 7.31
I have done a manual PLC update (http://myVeraIP:3480/data_request?id=update_plugin&Plugin=3086) but the problem is still there, i have also rebooted, but no joy
I am also getting this error when opening one of my PLEG’s: Error Getting status of: Heat 18 which worked before the update
I was surprised to see PLEG updating anyway, as I was on 7.33 and all was working fine. I did not trigger the update, it was a automatic update after a reboot
I am having the same issue. New user here so I am still learning the PLEG system. I am getting a version mismatch error as well, PLEG is 7.33, PLC 7.31. I also cannot add any new conditions or edit my existing conditions. I have been using PLEG for about two weeks. I have 4 inputs, 3 conditions, and 3 actions so I don’t believe I should be anywhere close to reaching the limit of the evaluation copy. Any help would be appreciated.
http://forum.micasaverde.com/index.php/topic,17624.msg214566.html#msg214566
