Has anyone gotten the ERGY plug in to work? All I get is a “waiting for data” screen. Running Vera 3 UI5
I had it working at one time. Vera3 UI5. You have to sign up for an account on their website and get a key to put into Vera, as I remember. I didn’t use it, so I haven’t looked at the tab in a while. But it is possible, I remember having to fuss with it some to get it to work.
i got it working one time. you have to register at the site but you have to go there through the dashboard option otherwise it got stuck up. i notified the people at ergy and they are looking into it. i got the screen and data loaded but the next day it says wrong gateway or key so probably there is some database which is not working as it should at there site.
ERGY seems to be working now (firmware 1.5.346). I couldn’t get “Activate Plug-In” to work until I entered “Energy used” (total watts) in the settings for one of my Z-wave switches.
still not working for me… says wrong gateway or key… its no big deal as the live usage works fine.
Managed to get access to ergy but now trying to load data …
I guess all the historical data has went to the bit-bucket to be recycled. See if anything ever shows up.
[quote=“ehillis, post:6, topic:170761”]Managed to get access to ergy but now trying to load data …
I guess all the historical data has went to the bit-bucket to be recycled. See if anything ever shows up.[/quote]
hence i aint using it
just wanted to see if i can help one out.
first u need a account which is made from the vera itself and not from the website of eemanager.net
then it suppose to work but u need at least one power/watt/temperature meter.
if you get a invalid gateway or wrong key error, go here : http://mios.eemanager.net and login with ur vera account
if you see the screen with the meters and stuff you can close that and go back to UI5 tab on browser and tab a ergy tab
go to settings and set the measuredevices to whole house for a mains-sensor and to renewable for other wattmeters and powermeters
now you have to wait a day for it to measure and do its thing. next day you would see a measurement.
And that is why I said I am waiting to see if it shows up.
so do i… for the 2nd week n counting…
