Did anyone try to make the equivalent to this trigger on openLuup with just variable watches? How can you have an and check for multiple variables (armed == 1 and motion == 1)?
Does the ALTUI LUA bit function as in a Vera scene where returning False would stop the rest of the scene execution?
Cheers Rene.
I’ve not tried exactly that, but I don’t see a problem with this.
Yes. Both in trigger code and in scene Lua.
Just tried it… my sensor has an Armed Tripped event and I set the trigger code up simply as ‘true’, as per the screenshot below. Tested and works just fine.
Lol, too easy :D. Thanks akbooer. one more moving over
Cheers Rene
