Enerwave ZWN-BPC and the latest firmware
Anyone other than me had trouble with the Enerwave ZWN-BPC PIRs and the latest firmware? 1.7.1320 for the Edge.
LEDs get’s stuck on. I assume the device is getting hammered by the vera. There was no response to motion. I let the sensors set for a long time. I excluded and then included then let them set a while longer. Only the Enerwaves PIRs gave me trouble.
I am having the same problems with version 1.7.10 for the VeraEdge only. Same issue, and everyonce in awhile it will work. Did you ever find a solution to this?
I have not. I wanted to see if anyone else was experiencing the issue so I could reply back to the support team.
