Hello all…
I would like to disable/enable notifications from certain zwave devices when a scene is set. Do I do this via LUUP or is there another way that I am not seeing in the gui. If via LUUP, can anyone provide sample code?
For example, I have door lock notifications set for code entered, bad code entered, door unlocked, door locked, and armed motion sensor tripped. I would like to set a scene for when I am home (not away) that disables these notifications.
I am using a scene (home) to unarm the motion senser, and would like to disable the door lock notifications when this scene is active, and then I would have another scene (away) to arm the motion sensor and I would like to enable the door lock notifications when this scene is active.
Thanks in advance for any asistance.
