Hi there,
I have foscam FI8918W
I have it showing in Vera as a device but there is no option to perform an action in Vera if motion is detected. Is it possible to add motion action for this model?
Hi there,
I would like to know about it too !!!
I have two and they have been working before.
Using UI7
I use Blue Iris and the virtual motion sensor plug-in.
[quote=“svaleb”]I would like to know about it too !!!
I have two and they have been working before.[/quote]
How did you have it setup and working previously? I assume on UI 5?
Yes, true.
I have it working in ui7, but not the motion sensor.
Did you do steps 10 & 11 of this post http://forum.micasaverde.com/index.php/topic,25282.0.html ? Worked for me.
yes, but it seems it does not work in ui7.
Thanks a lot this is what I have been looking for, worked!
Any one know why url links listed in Micsa forum don’t work through Tapatalk on phone (just takes you to the Micsa forum draft home page)? Other forums I use the links work ok on the phone:-/
But thanks again Packman!
Do you have night vision motion detection working in the plugin? It seems my plugin only detects motion when lights are on…
