I am having trouble adding my Edimax IC-9110w cam. I have found correct URL to the stream (on iSpy), filled in credentials, but I keep getting login screen when testing/adding in Vera like if the credentials were not accepted. Even after entering credentials at the Vera Test window popup, no luck.
I have Vera Edge/UI7, latest FW.
Screenshot attached.
Hope someone will help ![]()
Update: I was able to add it using another Guest/Anonymous user created on Edimax IP cam, which does not require autentisation. Now everything works. I have used .jpg URL, because mjpeg stream was very slow and it slowed my Vera, snapshot load is quick and sufficient for my use on Vera.
