Edimax Camera - Got it to work with Vera Edge
I installed the Vera Edge about 6 weeks ago and have just been playing around with dimmers and in-wall switch lights. I bought a Edimax IC-7001w and after a couple days of trying different configs, I finally got it to install and work properly. I tried numerous times to get Vera to find it automatically but that never worked.
I set the device add as follows:
Add Device → Security Camera → Generic IP Camera → manual install
Camera type = Other IP Camera
URL = < ip address of camera> :<port number ( I used 80 the default )>/snapshot.jpg ex: http://192.168.254.44:80/snapshot.jpg
Username = username you setup through the Edimax software
Password = password you setup through the Edimax software
Oddly, it appeared as though it did not add but when I logged out and logged back in a few minutes later it was there.
It was adding the port number ( even though 80 is the default ) that finally did the trick.
