I was using this on Smart things as garage door sensor - worked great.
It connects as a motion sensor on Vera UI7, which is not a problem. Tilt it and it it responds as motion / no motion - do I can live with it.
But it has limited motion range - this only works in one orientation on the garage door- and this it does perfectly.
Only the signal is inverted
ie motion shown when closed
no motion when open
If I could just invert the response (which CANT be done by inverting the sensor) I can happily live with it
How does one invert the display icon / response in Vera?
I use one on my garage. The icon is the UI7 door/window sensor (as opposed to an open or closed door icon) and the sense is correct. No indication when the door is closed, active when open.
