Ecolink Home Motion Sensor texting when armed
Everytime the Ecolink Home Motion Sensor is armed it sends me a text message even though I DO NOT have it set up to notify me. Is that normal? How do I control that?
You and setup an alert for your mode type (i.e. alert you when you have the system set to away) and you can also setup a separate alert under the sensor itself. Check and make sure both are turned off.
