Just connected Echo Dot to my Vera, followed all the instructions. When I go to issue a command “Alexa turn on lamp” I get the response “The hub Living Room Lamp is connected to isn’t responding Please check on the hub.”
I searched for forum for this type of error message, didn’t see anything.
An update: I have noticed that the “Alexa Helper” app was not installed.
I also have 3 devices connected. Thermostat, Outlet, and Deadbolt. I can successfully control the lock with Alexa, but if I try to access Thermostat or the Outlet I get the error message above.
Had this particular problem crop up yesterday, out of the blue as it were. A trip to the Alexa settings page and updating the Helper app. fixed it. I wonder what network changes may have prompted it?
+1
I had the same issue, followed all the steps and Alexa integration was not working.
Installed the helper plugin in the Vera WebUI (despite the warning not to install it manually) and it’s all working well!
