Easy way to reboot Vera secure via portal
Easy way to reboot Vera secure via portal:
settings => net & wifi then click on reboot on the right pane towards the top
much easier than removing the battery from the unit
Hope this helps
True. You can do that if the Vera Secure is up and working.
If it is inoperative (you got a “Down” alert), you will have to do the “press the reset button for 30 seconds” thing.
[quote=“gniknalu, post:2, topic:199074”]True. You can do that if the Vera Secure is up and working.
If it is inoperative (you got a “Down” alert), you will have to do the “press the reset button for 30 seconds” thing.[/quote]
A down alert when you’re not home to press the button is the kicker. Get a wifi plug you can access remotely for those “It’s dead Jim” moments.
