Duwi ZME_06436 Recognized as Dimmer [UI4]
My Duwi ZME_06436 is recognized as a Light Dimmer in my Vera2 UI4. I cant figure this out.
The switch/motorcontroll is working, but it seems a bit confusing on my remotes.
I found this LinuxMCE Thread with the same issue, but I cant get my head around the solution.
will be detected as drapes switch in the [b]latest z-wave code revision.[/b]
br Hari
What does that means? And is there something to update in Vera?
Thank you
putrid
