Duplex receptacle not working after power outage
The other day I had a power outage here at home, everything off and on several times. Finally once the power was restored one of my in wall duplex receptacles was not working. I am now getting a red flashing LED on the device and on my Vera I am getting “Unable to communicate with Device”
I have tried turning off the breaker that feeds the circuit for a few minutes and turning it back on but no change. Also tried a network heal, and restored a backup from the day before. All no luck…
Any ideas? Is there a way to get this thing to work?
Thanks so much!
Did you try an exclude then include? If that doesn’t work the receptacle is likely bad and will need to be replaced.
It’s helpful to post what specific devices you are working with. A recent poster indicated that they were experiencing an issue with CA3500 receptacles losing their configuration with power outages. exclude/include was the fix.
Thanks a bunch, I’ll give it a try since I think it is the CA3500. Its been installed for so long I don’t remember the model I had purchased.
