Duewi 05436 and "percentage" open on vera2
I have connected one of my blindingswitches to my Vera2 unit succesfully. Also configured my switch locally (physically) to stop on top and stop on bottom when window blinding is open or closed (0-100%) (after pairing).
But when I look in Vera I would expect this to be taken over. So that when I put the slider on 50%, the window blind opens at 50% and other values (0-100%). But is does not.
What am I doing wrong? How can I achieve this?
Btw. have searched intensively on the forum on all kind of keywords but didn’t find anything so excuse me if the question is double.
Hi there,
I would also be interested in a solution!
Greetings
Peter
Hi, might be very late answer. I have the same issue with an VeraLite. But it seems there is a calibartion mode for the D?wi 05436 Rollladen Aktor. Ccheck out the manual of the D?wi 054368 which seems to be the same? Not tried it yet, will do this weekend. YOu can find the manual on http://manuals.zwaveeurope.com/ Look for DUW_054368 manual.
