Dsc plugin red button error
So I’m getting an error message of “lau failure”
The evl3 works fine. Everything else on the vera is fine also.
J
Any input?
Thanks!
[quote=“jimim”]So I’m getting an error message of “lau failure”
J
Any input?
Thanks![/quote]
Indicates that the plugin is not connecting to the EVL3. If you restart (reload in the top right of the browser) does this fix this issue?
[quote=“Brientim, post:2, topic:176340”][quote=“jimim”]So I’m getting an error message of “lau failure”
J
Any input?
Thanks![/quote]
Indicates that the plugin is not connecting to the EVL3. If you restart (reload in the top right of the browser) does this fix this issue?[/quote]
Thanks! I got it. The ip actually changed when i had to reboot my router and switch the other day. i’m thinking i should give the vera a static ip actually so i don;t have this problem again, but not sure if i should? any advice?
jimi
Jim well done, you got it on one. Both Vera and your EVL3 should have reversed, static or fixed ip addresses to minimise future reoccurrences and sanity. So my advice is to apply your own advice
