I installed the IT-100 and an iTech Serial-to-Wifi adapter (works great using the power from the keybus, btw, so you don’t need an additional 120V plug nearby). The iTech uses IP port 4999 to communicate, and I can log entries in my Vera2 from my DSC panel. But I cannot set any parameters on the DSC. I believe it is because I cannot set the IP port number to communicate. I tried setting the ip address of 192.168.1.202:4999 in the field for IP address in the plug-in, but this does not seem to work. One way communication is better than nothing, but I’d like the ability to set parameters remotely. Does anyone know the proper way to do this?
Thanks for anything you can do to point me in the right direction.
