I am wondering if i may have needed to post this elsewhere (another thread) … if so please excuse me…
I have a dsc panel 1808 with the envisalink 3 and the vera 3… and another controller (primary Zwave controller)
problem i am trying to get status of alarm panel zones (breach / no breach …or doorlock locked/unlocked) feedback from the vera to show up on another priomary controller.
i.e on the vera i can see when door is locked and when door is unlocked…
i want to be able to “GET” THAT INFO from the vera and display it on another primary controller so as to see that the scenes being executed are actually being run properly…
for this i need the API Of the VERA3 apparently… where do i get this?
On Vera … you can use luup.variable_watch in some lua code … and send a message (using the remote API of the other controller) to indicate the state change of the alarm system.
One thing to keep in mind, the EVL3 interface allows devices to login and remotely control it via the TPI interface. Unfortunately, only one TPI login can be active at a time.
So if you are thinking about querying the EVL3 directly using the other controller, you are out of luck.
