is there any way to replace anything (eg the NT9005) by something else that would work? What are the key components needed to actually have a working DCS / Vera setup?
Essentially you need a power series panel (1616, 1832 or 1664), and keypad (Hybrid wireless keypad if you want to use wireless sensors) and either a DSC IT100 module (Also requires a USB to Serial adapter), or an Eyez-On EVL3.
Thanks so far. Although I have been reading most of the posts and stuff is probably well in all the existing content, it’s still not 100% clear.
Just to double check;
I Need the PC1616 (or 1832 or 1664) panel like this: [url=http://www.ebay.nl/itm/DIGITAL-SECURITY-CONTROLS-DSC-PC1616NKCP01-/310839690789?pt=US_Security_Cameras&hash=item485f7d4625&_uhb=1]DIGITAL SECURITY CONTROLS DSC PC1616NKCP01 | eBay
One thing to bear in mind with wireless motion sensors (compared to the wired counterparts) is that they have a little bit of a delay compared to the wired versions if you want to use them to trigger lights etc.
