Hi, when I arm/disarm from the keypad, the status does not change in vera, is there something that needs to be done to make this happen? Thanks.
Are you sure you have the plugin set up correctly and that it is using when your sensors are tripped. Can you control the panel from the plugin?
- Garrett
Hi, yes I can control the panel from the plugin. If I select AWAY it arms and HOME it disarms. But if I don’t use Vera to arm/disarm and use the physical keypad to arm/disarm, Vera’s status stays at the last mode that I used. Thanks.
Is there a setting somewhere that would allow Vera to poll the panel to determine status and then update itself accordingly. ie: panel is manually armed then Vern polls panel and see’s that it is armed and changes it’s status?
IT100 or Envisalink?
I’ve only observed the behavior you described with an IT100 when the serial cable had a broken RX/TX cable.
I’ve. Data flow in one direction was ok, but broken in the other direction.
In either case, there is no need to poll, since the adapter will deliver data to the plugin when the user makes changes manually at any of the keypads.
I have this working, I had to add additional scenes for when he partition is armed to change the house modules plugin to the correct mode.
