[quote=“techsan, post:52, topic:167215”]Alas I am back to pick the brains of those smarter that me with regard to the DSC plugin, or as I call it, the stress harbinger.
- The DSC plugin has been installed according to the wiki, 2. serial adapter via IT100 is recognized by Vera and has been associated with the plugin 3. scenario has been attempted with null modem adapter as well as without, however I am still unable to control any functionality of the DSC panel.
If I associate all three of the parameters as discussed in the wiki, Vera seems to loop as if looking for a functionality that is not there (note: I do not have motion sensors or smoke sensors connected to the DSC). If I remove all of the parameters except for the actual “Active Partition” field Vera pulls back a tab for the partition and gives me the “Away, Stay, No Delay, w/Code, and Disarm” buttons…all of which do nothing.
Is there something I’m missing in the advanced tabs or the setup of these tabs that the wiki does not go into? The wiki makes it seem extremely plug and play after copying a few lines into empty fields but I have yet to find that ease of installation.
P.S. the IT100 continually blinks green whether or not the serial adapter is connected to the Vera or not. Is this normal? Does this only indicate the IT100 is communicating with the DSC?
Thanks all, aside from this topic alone Vera has been great to me.[/quote]
@techsan,
Before @guessed releases his new plugin, you may as well try to see if you can this working!
First of all ignore the current WiKi instructions for configuration and Just enter the following (you may have to delete what you’ve typed there already):
If you have one partition then under “ActivePartitions” enter the number 1, If you have two partitions then enter 1,2 etc etc.
And then its the same for the zones also, so assuming you have 10 zones set up and you know the zone numbers, then just enter them exactly as follows in the “MotionSensors” variable: 1,2,3,4,5,6,7,8,9,10 this is assuming your zone numbers are in series (mine are not and thus I have 1,2,3,4,5,9,10,11,12).
There is nothing else to type other than whats in bold above!
Once you have saved the above then enter your PIN number (beware this will be sent to MCV’s servers!) and save again. If you have a four digit PIN (rather than 6 digits) then you’ll need to pad the end of the PIN with 00, e.g 123400
The best way to establish if you have communications is to try to set the clock; If it updates then you should be good to go! If it doesn’t work then try to either remove or insert the null modem and try again!
If none of the above works then something maybe wrong with your serial port setup!( perhaps post a picture of that?)
Oh and yes, the green light only indicates the IT100 is communicating with the panel!
Out of interest did you buy the IT100 new? The reason I ask was that if it was off eBay or similar (used), then somebody may have changed the baud rate and you may have to default it!
