DSC Alarm Integration - notify on alarm
Ok, so I have the Envisalink 3 all hooked up. I can:
Trigger off of door open / close
Arm / Disarm alarm remotely
Two rather basic things I am missing:
Trigger off of alarm being tripped - I would like to alert (SMS text) and turn on all lights if the alarm goes off
See status of alarm - armed/disarmed - I have two “scenes” that I can access on my Windows Phone (Grasshopper) one to arm, one to disarm. But I can’t see that STATUS of the alarm, like I would for a normal device (lamp, etc…)
Thanks,
Mike
I have a scene that does something similar.
Create the scene “Alarm tripped” or something.
Create a Trigger based on the DSC “System” device NOT the alarm panel. It’s the system that has the states you’re looking for, not the alarm panel. You’re looking for “Alarm Active”, pick a name etc as per below:
Device: #47 System
What type of event is the trigger?: Alarm Active
Name for this trigger:
Is Active? Device: Alarm is active
Optional: Which of the following users should be notified when the event occurs?:
Now I execute a Luup Event on this trigger (for Sonos TTS & others). You could do that or control devices directly. Have fun!
Weird… that option was not showing before, but is now. Thanks.
What about showing the status of the alarm (armed or not). I would like to be able to see this from my Windows Phone app.
Thanks,
Mike
Changing the subject for accuracy. Any way to indicate the armed/disarmed status of the alarm? similar to any other lamp. I’d like to be able to see the status from my phone app.
Which app are you using? automator.app (iOS) or AutHomation (android) will show the status.
Otherwise, you can set up a scene to send a prowl notification with the following luup code (replace xx with your alarm partition device #, replace yy with your prowl API key). Set the trigger to whichever status you are looking to track (i.e. armed, failed to arm, disarmed, etc):
local alarmstatus = luup.variable_get(“urn:micasaverde-com:serviceId:AlarmPartition2”, “DetailedArmMode”, xx)
luup.inet.wget(“https://api.prowlapp.com/publicapi/add?apikey=yy&application=Home!&description=Alarm%20” … alarmstatus … “&priority=-1”)
Oops, ignore that part about prowl. Turns out vera wasn’t polling the alarm fast enough to send accurate sensor status.
Here’s a better way to use vera with prowl for alarm status:
[ul][li]Create a new scene.[/li]
[li]Create scene triggers for your alarm device for each of the states you want to monitor (i.e. Armed, Disarmed, Stay)[/li]
[li]On the trigger management page for the new scene, put Luup code to send an HTTP post notification to prowl. Here’s a sample (replace xxx with your own prowl API key): luup.inet.wget(“https://api.prowlapp.com/publicapi/add?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&application=Home%20Alarm&description=Armed&priority=-1”)
[/li][/ul]
Good luck.
I use the iphone automator app & that shows me the status with a nice padlock icon. Again the System is the device to look at, not the panel. Which app?
I’m using Grasshopper for Windows Phone as my mobile app. It shows status of each zone, but doesn’t seem to understand the device created by the DSC Alarm plugin app for Vera. The one that shows the status on Vera web page.
I even thought of the possibility of creating a “dummy” lamp device. Then I could have it turn On or Off based on the alarm being armed or not. I’d simply label the device “Alarm Status” and be done. I’m not sure how to do that though.
I emailed the author of Grasshopper (who also participates in this forum) to see if the app could be modified. I’d certainly offer whatever assistance I could. It’s really the last puzzle piece in my home automation obsession… …oh wait, no, irrigation is next… it never ends! :slight_smile:
I’m currently working to get the WP8 grasshopper client beta ready. If you are anxious please download the Windows client on the marketplace and do the 2 week trial. I just recently updated it to include the control for alarm systems. I was hoping someone could test them for me since i don’t own one. I’m hoping microsoft puts in place a beta feature similar to the phone marketplace.
Is it possible to alert which zone was tripped with vera alerts on the alarm scene?
