For anyone who’s interested, here’s the final code;
[code]<?xml version="1.0"?>
local http=require("socket.http")
local https = require ("ssl.https")
local lfs = require("lfs")
local consumer_key = "....."
local consumer_secret = "....."
local access_token=""
local access_token_secret=""
function send_all_images_to_dropbox(lul_data)
local dropbox = tonumber(lul_data)
luup.log("sending all cameras to Dropbox "…dropbox)
for k,v in pairs(luup.devices) do
if( v.category_num==6) then -- Camera
send_image_to_dropbox(dropbox,k)
function send_image_to_dropbox(dropboxIn,webcamIn)
local dropbox = tonumber(dropboxIn)
local webcam = tonumber (webcamIn)
access_token=luup.variable_get("S_WebcamDropboxUploaderSettings1.xml","AccessToken",dropbox)
access_token_secret=luup.variable_get("S_WebcamDropboxUploaderSettings1.xml","AccessTokenSecret",dropbox)
if(access_token and access_token_secret) then
if(access_token~="" and access_token_secret~="") then
luup.log("sending device "..webcam.." images to Dropbox "..dropbox)
local downloadUrl=“http://”…luup.devices[webcam].ip…luup.variable_get(“urn:micasaverde-com:serviceId:Camera1”,“URL”,webcam)
if(luup.devices[webcam].user and luup.devices[webcam].pass) then
if(luup.devices[webcam].user ~=“” and luup.devices[webcam].pass ~=“”) then
downloadUrl=“http://”…luup.devices[webcam].user…“:”…luup.devices[webcam].pass…“@”…luup.devices[webcam].ip…luup.variable_get(“urn:micasaverde-com:serviceId:Camera1”,“URL”,webcam)
local tempfile = ltn12.sink.file(io.open('/tmp/tempimage.jpg', 'wb'))
http.request {
url = downloadUrl;
sink = tempfile;
local now=os.time()
local filename=luup.devices[webcam].description..os.date("_%Y_%m_%d_%H_%M_%S",now)..".jpg"
local foldername=os.date("%Y_%m_%d",now)
local dropboxUrl = "https://api-content.dropbox.com/1/files_put/sandbox/"..foldername.."/"..filename
math.randomseed( os.time() )
local nonce=math.random(99999999)
local post_headers = "realm=\""..dropboxUrl.."\", oauth_timestamp=\""..now.."\", oauth_version=\"1.0\", oauth_signature_method=\"PLAINTEXT\", oauth_consumer_key=\""..consumer_key.."\", oauth_token=\""..access_token.."\", oauth_signature=\""..consumer_secret.."%26"..access_token_secret.."\", oauth_nonce=\""..nonce.."\""
local filesize = lfs.attributes ('/tmp/tempimage.jpg', "size")
local response_body = { }
local res, code, response_headers =https.request
url = dropboxUrl;
method = "PUT";
headers =
["Content-Length"] = filesize ;
["Content-Type"] = "text/plain";
["Authorization"] = "OAuth "..post_headers;
source = ltn12.source.file(io.open("/tmp/tempimage.jpg"));
sink = ltn12.sink.table(response_body);
--luup.log("Status:".. res and "OK" or "FAILED")
--luup.log("HTTP code:".. code)
--luup.log("Response headers:")
--if type(response_headers) == "table" then
-- for k, v in pairs(response_headers) do
-- luup.log(k.. ":".. v)
-- end
--end
--luup.log("Response body:")
--if type(response_body) == "table" then
-- luup.log(table.concat(response_body))
--end
if(code==200) then
luup.log("Dropbox file for webcam "..webcam.." sent successfully")
else
luup.log("Dropbox file for webcam "..webcam.." failed")
os.remove('/tmp/tempimage.jpg')
function removeOldFiles(dropboxIn)
local json=require("dropbox_json_parser")
local daysToKeep=luup.variable_get("S_WebcamDropboxUploaderSettings1.xml","DaysToKeep",dropbox) or 14
local secondsToKeep=daysToKeep*86400
local now=os.time()
local dropboxUrl = "https://api.dropbox.com/1/metadata/sandbox/"
url = dropboxUrl;
method = "GET";
headers =
local dir_list=json.decode(table.concat(response_body))
local dir_contents=dir_list["contents"]
local pattern = "(%d+)_(%d+)_(%d+)"
for i,content in ipairs(dir_contents) do
if(content["is_dir"]) then
folderName=string.sub(content["path"],2)
year,month,day=folderName:match(pattern)
if(year) then
folderDay=os.time({day=day,month=month,year=year,hour=0,min=0,sec=0})
if(folderDay) then
luup.log(folderDay)
if((os.time()-folderDay)>secondsToKeep) then
now=os.time()
dropboxUrl = "https://api.dropbox.com/1/fileops/delete?root=sandbox\038path="..folderName
response_body = { }
url = dropboxUrl;
method = "POST";
headers =
luup.log("Done cleaning up")
function removeOldFilesLoop(lul_data)
removeOldFiles(lul_data)
local dropboxNumber=tonumber(lul_data)
luup.call_delay('removeOldFilesLoop',86400,dropboxNumber,true)
function sendImagesLoop(lul_data)
local update_frequency=luup.variable_get("S_WebcamDropboxUploaderSettings1.xml","SendFrequency",lul_data) or 10
luup.log("Dropbox update frequency= "..update_frequency.." minutes")
update_frequency=update_frequency*60
if(update_frequency>0) then
luup.call_delay('sendImagesLoop',update_frequency,dropboxNumber,true)
function lug_startup(lul_device)
sendImagesLoop(lul_device)
removeOldFilesLoop(lul_device)
lug_startup
urn:milliesoft-com:serviceId:WebcamDropboxUploader1
SendAllSnapshots
do
send_all_images_to_dropbox(lul_device)
return 4,30
SendSnapshot
do
local webcamNumber = tonumber(lul_settings.webcamNumber)
send_image_to_dropbox(lul_device,webcamNumber)
return 4,30
[/code]
