Hello,
is the second picture from a code sent from the app ?
kind regards
Hello,
kind regards
Hello,
perhaps we can continue to talk with each other on a more user friendly
platform, for example “Teamviewer” or another chat program. Teamviewer is
also available for desktop (windows).
It takes a lot of time to communicate thru vera forum !!
kind regards,
[quote=“GreatGazoo, post:41, topic:198330”]Hello,
kind regards[/quote]
picture Power OFF ?
No? from plugin.
[quote=“GreatGazoo, post:42, topic:198330”]Hello,
kind regards,[/quote]
yes, tomorrow I will write the login and password for Teamviewer!
Hello,
2 days ago I posted a new json file on Telegram, this one has an extra tab
in the Top Navigation Bar, I tested it several times and on this site everything is
working fine.
Could you please be so kind and test this file at your side ??
Hope to hear your (positive) feedback soon !!
Kind regards,
Where can I access the plugin files?
Hello,
Thanks for your interest in the DreamColor Plugin.
In earlier days I attached the plugin files to the first post in this topic, but seems to be that
those links are not present on the forum anymore.
Here you have a link to my Github page where you can download the files GitHub - GreatGazoe/DreamColorLEDRGB: Plugin Vera controller (z-wave) for controller ws2812b led strip..
Hope you will enjoy the plugin !!
kind regards
Thanks so much.
Did the 104 firmware issue get sorted? I seem to be having the same issue.
Hello,
What do you exactly mean with “104 firmware issue” ?
Does this mean the plugin isn’t functioning well ?
I tried to search the vera forum for this issue but cannot find anything about it.
Hope to hear from you soon,
kind regards
Thank for your response.
No it’s not controlling the H806SB. The commands aren’t failing though. Im just not seeing changes in the LED’s.
I was referring to @alekseyzp on Feb 17 having issues. He is running the same firmware 104.
Please help.
Warm regards,
Jordan
hello,
did you choose the IP-adress correctly (from the H806SB).?
Did you choose the right port (4626) ?
hope to hear from you soon,
Yes to both.
The port auto populate.
When I first created the plugin device there was an option to input the file number. This has gone and I now only have two sliders with no labels and a colour selector. Has the plugin installed correctly.
hello,
I know there are some interface issues around different devices.
what device are you on (vera-3/plus/secure/) ?
do you have AltUi installed (vera app) ?
if yes, can you try to use the plugin there and see if the commands are functioning
and the only problem is the interface ?
kind regards,
I’m running a Vera edge.
I’ve just installed AltUi.
How do run the plugin there?
hello,
under tab "devices"you should see the dreamcolor plugin,
there has to be a brightness slider, color control option and an on/off switch.
Try to control the lights, is it functioning ?
kind regards,
Okay, I found it.
It doesn’t work from there either.
It does work from the H806SB iPhone app.
hello,
let us communicate thru a chat app, that’s a little bit easier.
do you have telegram installed (windows/iPhone) ?
kind regards
Hello,
if you are done with installing Telegram you can use this link to
contact me. Telegram: Join Group Chat
Kind regards,
I’ve joined the chat.
