Drain Valve suggestions / Help
I have a home that we “close” down every time we leave it. This includes turning off the water pump, hot water heater, and opening sink valves to drain water / pressure out of pipes in case of freeze condition. I have everything figured out except how to drain water. I have seen the valves made by fortrezz, but at $400+ I’m looking for something more affordable.
I need suggestions on how I can achieve water drainage / pressure relief that is somewhat affordable. Retrofitting something into plumbing is not an issue.
