I’ve tried to set up Vera Alert to send my a Picture when an armed motion detector is trippet,
In the message field I’ve typed {Picture(#74)}
On my S2 I only get Download Error = Error
appreciate the input.
That should be {Picture(74)} (i.e. without the number sign).
But if your problem is the same as mine this will only switch from “Download Error = Error” to “Download Error =” (no parameters at all…).
Yes, I’ve tried to remove the number sign and the error message I got was what you wrote. I kind of gave up the ‘send picture’ when motion. Mayby someday in the future it will work properly.
I experienced the same Error.
