I have an issue with my ZXT-120, I was trying to test out if its going to work to UI 7 with following the instructions, It seems that its not working. So I tried UI5, so I upgraded it to that. But when I downgraded it, I couldn’t access my device. I had a backup before installing the old UI. Then after restarting the router and everything, the application just converted back to UI 7 and lo and behold, it says the message ZWave Failed to Start, even if your changing the dashboard. I already loaded the backup file. Are there any issues with downgrading Veralite?
