Hello,
I’d like to downgrade to UI5 from UI7 on a Veralite G. I tried putting this into the custom URL field: http://download.mios.com/rt3662_betafirmware/rt3662_Luup_ui5-1.5.622-en-mios.squashfs
At first, it seemed like it would work. Then it said that the update was failed. I am still running UI7. Should I try it again, or is there another URL I should use?
I’ve already gotten the force upgrade removed from my Vera (I think).
Thanks for the help.
Have a look at this thread:
http://forum.micasaverde.com/index.php?topic=26766.0
Note that if your unit defaulted with UI7, it may need to have a support ticket raised or otherwise, if will immediately revert to Back… Designed solution
Already changed to UI5. And gave a support ticket, the problem now is I can’t even access the static IP for the Vera, I’m probably stuck. I also used that version as well. Since the default of my vera is also UI7. I’m still waiting for the support team on how I can go back, since UI7 to UI5 is kind of buggy. I don’t know why ???
