Hi Folks,
Trying to parse out what pin was used to open the door from an sdata request. It seems that I should be able to get that data from the last used parameter in the ?pincodes? json variable but it doesn?t seem to reliably update. If I add or remove a pin code then it will pick up the latest used date for the pins already in there, but it doesn?t do so unless you do something to change the pins. Is this just a matter of vera caching that data and not realizing that it needs to be updated and so a bug in the latest UI5 firmware? Or is it a limitation in my schlague lock somehow?
I?ve got a veralite running UI5. I know that you?re supposed to be able to create a scene to be triggered when a pin code is entered but I can?t get that to work either and i would prefer to get the data from the JSON response that is telling me the lock was unlocked.
Any suggestions welcome, thank you!
