Doorbell Activation
I cannot figured out one thing, hope some can help me with it.
I just wanna activated my doorbell between a specified time. For example; when someone presses the press button at the front door, it will activated my trigger for the doorbell. But when someone presses the press button at the front door late at night it will not activated my trigger. How can i manage this to work?
Do you have the doorbell wired to a zwave sensor already?
Yes i have. I can see the press button and also the zwave doorbell in vera lite
I assume you have an old fashioned wired doorbell. One possibility is to use an isolated contact relay somewhere in the doorbell-chime wiring. If you go this route, please be aware the devices I’ve seen for this are about the size of your fist–so might not be terribly discreet. Also those units are powered so you’ll need 120V AC (if you’re in the US) to supply to the contact relay itself.
Another thing you might consider is to use one of those newfangled smart doorbells that are starting to come out. Such as skybell or doorbot. I would strongly recommend you read reviews first though as most people are having great difficulty with early models.
[quote=“RSKok, post:1, topic:179265”]I cannot figured out one thing, hope some can help me with it.
I just wanna activated my doorbell between a specified time. For example; when someone presses the press button at the front door, it will activated my trigger for the doorbell. But when someone presses the press button at the front door late at night it will not activated my trigger. How can i manage this to work?[/quote]
If you have a direct association between your Z-Wave button and the bell, then there is no way to schedule its “Armed” state.
If you use a Programmable Logic Event Generator(PLEG) based scene to activate your bell based on a trigger from the button, you can set a schedule where the action will occur only during the hours that you specify.
Edit: Without PLEG, using only Vera’s native scenes and some LUA coding, you can use @Rex Beckett’s LUA code example to create your own scene schedule.
Just thought I would “chime” in hear as this seems to “ring” true with my experience… okay I will stop that now.
What set up specifically do you have? There is another really good thread on doorbell set up on the forum if you search for something around “Everspring UTSE03A Z-Wave Door Bell Set”
The Everspring UTSE03A Z-Wave Door Bell Set will connect with vera but does not work properly - most have ditched it and just kept the chime as it is possible to make this work with vera. For the push button most are using a normal dry contact button push connected to a fabiro window sensor. the push button then activates a “trip” in vera and as such you can then use PLEG to do what ever you want.
Set up works great and the thread mentioned has all the info you are likely to need.
as for the time issue a post in the PLEG thread is likely best but I think it will be something like (Time_from; Trip; time_until)
[quote=“Z-Waver, post:5, topic:179265”][quote=“RSKok, post:1, topic:179265”]I cannot figured out one thing, hope some can help me with it.
Edit: Without PLEG, using only Vera’s native scenes and some LUA coding, you can use @Rex Beckett’s LUA code example to create your own scene schedule.[/quote]
PLEG worked for me, that did the trick. In PLEG when i actived it, the doorbell will chime, and in bypass mode it will not. So the next step i did was add a schedules for actived and bypass.
Thanks for pointing me in the right direction!
