Door/Window and Motion sensors: Very long delays
I have a Vera 3/UI5. I’ve had my system up and operating for almost 2 years and have experienced very few problems. About 3 weeks ago I noticed delayed actions after event triggers. Normally the little “running man” would go from green to red to green within a second after I opened/closed a door/window. Now it can be 10 minutes before any change in the running man icon and the system restarts several times. And everything else on the system is delayed until the running man changes back to green. For example if I trigger a light to come on due to a motion sensor trigger, that light won’t come on for 10 minutes. This action happens on all my doors and windows. My motion sensors are somewhat affected too but not to the extreme time that I described. The major things I did prior to this problem was install the Harmony Hub plugin and I moved my cameras to the Blue Iris plugin. I have since removed both plugins but the problem and restarts persisted so I put them back in since I don’t believe they are the culprits. I have gone to a backup that was weeks before the problem started but the problem was still there. I’ve gone through several backup restorals and the delay and restarts are still there. I even did a restore to factory default and reloaded an even earlier backup…and that didn’t fix it. I’ve done Heals and reconfigure devices but still nothing.
I started a problem ticket on this over 3 weeks ago and all I heard from them was to enable tech support and give them the ability to remotely look at my system. And then nothing. Can anyone here give me a clue as to where I can start to fix this issue. I’m thinking I may have corrupt motion sensor files but that is a guess.
