I have an issue with a door sensor (AEOTEC BY AEON LABS Z-WAVE PLUS DOOR WINDOW SENSOR 6 ZW112). It is battery powered and has altid 26. Most of the time it does not work (though sometimes it does), probably because it is too far from Vera Plus controller.
The routing should be like this:
1-19-26
or
1-19-20-26
19 and 20 are line-powered devices physically very close to the sensor 26. The both work very reliably. But they don’t have the 26 in their Neighbors variable. And the sensor 26 does not see them either. When I go to see the variables on the sensor, it only says:
Neighbors: 1,
All of the devices are Z-Wave Plus Gen5, which are supposed to have a good range.
So how do I make the routing work? Obviously range is not an issue here since 19 and 20 work fine. The problem is I can’t make the routing update to include 26. Any idea how to do it? I wrote to Vera support, and their only suggestion was to add more intermediate devices. Which is unnecessary, since I already have enough.
